Api session event editor cinematic remove keypoint
Revision as of 15:46, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorcinematic/remove_keypoint/
Description: Remove Key Points from Cinematics
0 REQUIRED (CINEMATIC_DATA Integer ID or multiple integer values in array [1, 2, 3]) Cinematic Datas
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Key Point IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint/", options)
