Api session event participant money transfer give
API Endpoint: api/session/event/participant/money_transfer_give/
Description: Stakeholder transfers money to another Stakeholder.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (seller) | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (receiver) | |
| 2 | REQUIRED | (Enumeration) | Type of transfer | LAND, SUBSIDY or TRANSFER |
| 3 | REQUIRED | (String) | Transfer Message | |
| 4 | REQUIRED | (Floating point number) | Amount |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/money_transfer_give/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Transfer Message", 2 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/participant/money_transfer_give/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Transfer Message", 49 ]'JavaScript example POST
body: '[ 1, 1, "SUBSIDY", "Transfer Message", 2 ]'
fetch("https://engine.tygron.com/api/session/event/participant/money_transfer_give/", options)
