Api session event participant map sell land
Revision as of 15:33, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/map_sell_land/
Description: Stakeholder plans to sell owned land within the MultiPolygon to another Stakeholder for a given price.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (seller)
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder (receiver)
2 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
3 REQUIRED (Floating point number) Price per square meter
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/map_sell_land/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 73 ]
Curl example multi item POST
[ 1, 1, {
}, 68 ]
JavaScript example POST
 body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 73 ]'
fetch("https://engine.tygron.com/api/session/event/participant/map_sell_land/?crs=3857", options)
