Api session event logic money transfer add
API Endpoint: api/session/event/logic/money_transfer_add/
Description: Create a Money Transfer between two Stakeholders.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (from) | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (to) | |
| 2 | REQUIRED | (Enumeration) | Money Transfer Type | LAND, SUBSIDY or TRANSFER |
| 3 | REQUIRED | (String) | Provided motivation | |
| 4 | REQUIRED | (Floating point number) | Transfer amount |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/money_transfer_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Provided motivation", 76 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/logic/money_transfer_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Provided motivation", 20 ]'JavaScript example POST
body: '[ 1, 1, "SUBSIDY", "Provided motivation", 76 ]'
fetch("https://engine.tygron.com/api/session/event/logic/money_transfer_add/", options)
