Api session event logic measurement save
Revision as of 15:33, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/measurement_save/
Description: Save a Measurement.
0 REQUIRED (MEASUREMENT Integer ID) Measurement
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/measurement_save/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_save/", options)
