Api session event logic action log export
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/action_log_export/
Description: Export history of Actions taken by Stakeholders.
200 byte[] (byte array)
curl 'https://engine.tygron.com/api/session/event/logic/action_log_export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/logic/action_log_export/", options)
