Api session event answer measure zoning permit denied
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/answer/measure_zoning_permit_denied/
Description: Zoning plan permitter denied the Measure
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (MEASURE Integer ID) Measure
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/measure_zoning_permit_denied/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/measure_zoning_permit_denied/", options)
