Api session event answer measure construction approval confirm
API Endpoint: api/session/event/answer/measure_construction_approval_confirm/
Description: Owner of Measure confirms the continuation of the planned construction
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 1 | REQUIRED | (MEASURE Integer ID) | Measure | |
| 2 | REQUIRED | (true, false) | Confirms | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/measure_construction_approval_confirm/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'JavaScript example POST
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/measure_construction_approval_confirm/", options)
