Api session event answer land buy refused
API Endpoint: api/session/event/answer/land_buy_refused/
Description: Selling Stakeholder refused selling the specified land at a given price per square meter to Buying Stakeholder.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (buying) | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder (selling) | |
| 2 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon | |
| 3 | REQUIRED | (Floating point number) | Price per square meter |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/land_buy_refused/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 8 ]
'Curl example multi item POST
[ 1, 1, {
}, 46 ]
'JavaScript example POST
body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 8 ]'
fetch("https://engine.tygron.com/api/session/event/answer/land_buy_refused/?crs=3857", options)
