Api session event answer building construction approval confirmed
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/answer/building_construction_approval_confirmed/
Description: Owner of Building confirms the continuation of the planned construction
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
1 REQUIRED (BUILDING Integer ID) Building
2 REQUIRED (true, false) Confirms true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/building_construction_approval_confirmed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/building_construction_approval_confirmed/", options)
