Api session event editor trigger set method
API Endpoint: api/session/event/editortrigger/set_method/
Description: Set the Request Method of a Trigger.
| 0 | REQUIRED | (TRIGGER Integer ID or multiple integer values in array [1, 2, 3]) | Triggers | |
| 1 | REQUIRED | (Method or multiple values in array [a, b, c]) | Request Methods |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_method/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "GET" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_method/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "GET", "POST", "POST" ] ]'JavaScript example POST
body: '[ 1, "GET" ]'
fetch("https://engine.tygron.com/api/session/event/editortrigger/set_method/", options)
