Api session event editor source set description
API Endpoint: api/session/event/editorsource/set_description/
Description: Set the description of a Source.
| 0 | REQUIRED | (SOURCE Integer ID) | Source | |
| 1 | REQUIRED | (String) | Description |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorsource/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Description" ]'JavaScript example POST
body: '[ 1, "Description" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/set_description/", options)
