Api session event editor source add file
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsource/add_file/
Description: Add a new File Source, given a Name and Uploader.
0 REQUIRED (String) File Name
1 REQUIRED (String) Uploader Name
200 Integer (File Source ID)
curl 'https://engine.tygron.com/api/session/event/editorsource/add_file/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "File Name", "Uploader Name" ]'
JavaScript example POST
 body: '[ "File Name", "Uploader Name" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_file/", options)
