Api session event editor sound set loop
Revision as of 15:32, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsound/set_loop/
Description: Set whether a Sound loops.
0 REQUIRED (SOUND Integer ID) Sound
1 REQUIRED (true, false) Loop true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsound/set_loop/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorsound/set_loop/", options)
