Api session event editor netnode remove
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetnode/remove/
Description: Remove existing Net Node
0 REQUIRED (NET_NODE Integer ID or multiple integer values in array [1, 2, 3]) Net Nodes
curl 'https://engine.tygron.com/api/session/event/editornetnode/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editornetnode/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetnode/remove/", options)
