Api session event editor netcluster remove network
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetcluster/remove_network/
Description: Remove a Network of a particular Net Type, with the option to keep the Root Load.
0 REQUIRED (Enumeration) Net Cluster ELECTRICITY, GAS, HEAT, INTERNET or SEWER
1 REQUIRED (true, false) Keep Root Load true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/remove_network/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", true ]'
JavaScript example POST
 body: '[ "ELECTRICITY", true ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/remove_network/", options)
