Api session event editor measure set event
API Endpoint: api/session/event/editormeasure/set_event/
Description: Change an pre-existing event of a specific Action Type of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID or multiple integer values in array [1, 2, 3]) | Measures | |
| 1 | REQUIRED | (Boolean or multiple boolean values in array [true, false, true]) | Server Side (false = Client Side) | |
| 2 | REQUIRED | (ActionType or multiple values in array [a, b, c]) | Action Types | |
| 3 | REQUIRED | (CodedEvent or multiple values in array [a, b, c]) | CodedEvents |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, true, "CONSTRUCTION_PLAN", {
"id" : -1,
"parameters" : [ ]
'Curl example multi item POST
[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL" ], [ {
"id" : -1,
"parameters" : [ ]
"id" : -1,
"parameters" : [ ]
"id" : -1,
"parameters" : [ ]
'JavaScript example POST
body: '[ 1, true, "CONSTRUCTION_PLAN", { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_event/", options)
