Api session event editor measure set description
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/set_description/
Description: Set the description of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure
1 REQUIRED (String) Description
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Description" ]'
JavaScript example POST
 body: '[ 1, "Description" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_description/", options)
