Api session event editor measure add building
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/add_building/
Description: Add a new Building to specified Measures
0 REQUIRED (MEASURE Integer ID or multiple integer values in array [1, 2, 3]) Measures
200 Integer[] (Building IDs)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_building/", options)
