Api session event editor measure add
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasure/add/
Description: Add Measure for Stakeholder
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
200 Integer (Measure ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add/", options)
