Api session event editor map set height geotiff
Revision as of 15:30, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormap/set_height_geotiff/
Description: Update Elevation Model using a GeoTIFF
0 REQUIRED (GEO_TIFF Integer ID or multiple integer values in array [1, 2, 3]) GeoTIFFs
200 Integer (Amount of sectors updated)
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editormap/set_height_geotiff/", options)
