Api session event editor geolink set matching
API Endpoint: api/session/event/editorgeolink/set_matching/
Description: Match incoming features against this Attribute name and value.
| 0 | REQUIRED | (GEO_LINK Integer ID or multiple integer values in array [1, 2, 3]) | Geo Links (custom) | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"] or matrix [["a", "b"], ["c", "d"], ["e", "f"]]) | Numeric Attribute Values | |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_matching/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1", [ "A1", "B1" ] ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_matching/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ "A1", "B1" ], [ "A2", "B2" ], [ "A3", "B3" ] ] ]'JavaScript example POST
body: '[ 1, "Attribute Name 1", [ "A1", "B1" ] ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/set_matching/", options)
