Api session event editor geolink add
API Endpoint: api/session/event/editorgeolink/add/
Description: Add a new CustomGeoLink with a name and a Geo Link Type
| 0 | REQUIRED | (GeoLinkType or multiple values in array [a, b, c]) | Geo Link Types | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Names |
| 200 | Integer[] (CustomGeoLinks) |
curl 'https://engine.tygron.com/api/session/event/editorgeolink/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "AREA", "Name 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "AREA", "BUILDING", "ROAD" ], [ "Name 1", "Name 2", "Name 3" ] ]'JavaScript example POST
body: '[ "AREA", "Name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/add/", options)
