Api session event editor functionoverride remove category
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorfunctionoverride/remove_category/
Description: Remove a Category from a Function, if it has more than one
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (Enumeration) Category AGRICULTURE, BRIDGE, EDUCATION, GARDEN, HEALTHCARE, INDUSTRY, INTERSECTION, LEISURE, LUXE, NATURE, NORMAL, OFFICES, OTHER, PARK, PAVED_AREA, ROAD, SENIOR, SHOPPING, SOCIAL, STUDENT or UNDERGROUND
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_category/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "SOCIAL" ]'
JavaScript example POST
 body: '[ 1, "SOCIAL" ]'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/remove_category/", options)
