Api session event editor eventbundle set event
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoreventbundle/set_event/
Description: Replaces a Coded Event of an Event Bundle based on its ID
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (true, false) Serverside true or false
2 REQUIRED (CodedEvent) Coded Event
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/set_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, true, {
 "id" : -1,
 "parameters" : [ ]
JavaScript example POST
 body: '[ 1, true, { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/set_event/", options)
