Api session event editor eventbundle remove event
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoreventbundle/remove_event/
Description: Remove a Coded Event of an Event Bundle
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (true, false) Serverside true or false
2 REQUIRED (Integer number) Coded Event ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, 1 ]'
JavaScript example POST
 body: '[ 1, true, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/remove_event/", options)
