Api session event editor chat set tools
API Endpoint: api/session/event/editorchat/set_tools/
Description: Set the Agent Tools of a Chat Channel.
| 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) | Chat Channels | |
| 1 | REQUIRED | (AgentTool or multiple values in array [a, b, c]) | Array of Agent Tools |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editorchat/set_tools/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ [ "VALIDATE_ENDPOINT", "GET_SCREEN" ], [ "VALIDATE_ENDPOINT", "GET_PAGE" ], [ "GET_SCREEN", "VALIDATE_ENDPOINT" ] ] ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/set_tools/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ [ "GET_IMAGE", "EXECUTE_QUERY" ], [ "GET_IMAGE", "VALIDATE_QUERY" ], [ "EXECUTE_QUERY", "GET_IMAGE" ] ] ]'JavaScript example POST
body: '[ 1, [ [ "VALIDATE_ENDPOINT", "GET_SCREEN" ], [ "VALIDATE_ENDPOINT", "GET_PAGE" ], [ "GET_SCREEN", "VALIDATE_ENDPOINT" ] ] ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/set_tools/", options)
