Api session event editor chat add item channel
API Endpoint: api/session/event/editorchat/add_item_channel/
Description: Add a new Chat Channel related to specfic Item
| 0 | REQUIRED | (MapLink or multiple values in array [a, b, c]) | Item Maplink | |
| 1 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Item ID |
| 200 | Integer[] (Chat Channel IDs) |
curl 'https://engine.tygron.com/api/session/event/editorchat/add_item_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "SETTINGS", 1 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/add_item_channel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "SETTINGS", "ACTION_MENUS", "ADDRESSES" ], [ 1, 2, 3 ] ]'JavaScript example POST
body: '[ "SETTINGS", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorchat/add_item_channel/", options)
