Api session event editor building add geometry
API Endpoint: api/session/event/editorbuilding/add_geometry/
Description: Add a Custom Geometry to a Building
| 0 | REQUIRED | (BUILDING Integer ID or multiple integer values in array [1, 2, 3]) | Buildings | |
| 1 | REQUIRED | (CUSTOM_GEOMETRIE Integer ID or multiple integer values in array [1, 2, 3]) | Custom Geometries | |
| 2 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Primary Building for the Custom Geometry, per Building | |
| 3 | OPTIONAL | (SOURCE Integer ID) | Source |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ true, false, true ] ]'JavaScript example POST
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/", options)
