Api session event editor building add polygons
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/add_polygons/
Description: Add Polygons for Building Section. If the Building is empty, optionally set ownership to the largest Plot Owner of the provided MultiPolygon
0 REQUIRED (BUILDING Integer ID or multiple integer values in array [1, 2, 3]) Buildings
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Section ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon
3 REQUIRED (true, false) Use largest Owner true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, false ]
Curl example multi item POST
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
} ], false ]
JavaScript example POST
 body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, false ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857", options)
