Api session event editor attributeaction set image
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorattributeaction/set_image/
Description: Set the image of an Attribute Action
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple integer values in array [1, 2, 3]) Attribute Actions
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Images
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Image 1" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/set_image/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Image 1", "Image 2", "Image 3" ] ]'
JavaScript example POST
 body: '[ 1, "Image 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/set_image/", options)
