Api session event editor attributeaction set attribute
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorattributeaction/set_attribute/
Description: Set Attribute Action numeric Attribute value
0 REQUIRED (ATTRIBUTE_ACTION Integer ID or multiple integer values in array [1, 2, 3]) Attribute Actions
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Numeric Attribute Values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/set_attribute/", options)
