Api session event editor area remove group
Revision as of 15:29, 10 November 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorarea/remove_group/
Description: Remove the provided group Attributes
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) Group Attributes
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Group Attribute 1"'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_group/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Group Attribute 1", "Group Attribute 2", "Group Attribute 3" ]'
JavaScript example POST
 body: '"Group Attribute 1"'
fetch("https://engine.tygron.com/api/session/event/editorarea/remove_group/", options)
