Api session event editor overlay add legend entry
Revision as of 13:28, 3 November 2026 by Frank@tygron.nl (talk | contribs)
This functionality is deprecated and will be removed in the future.
API Endpoint: api/session/event/editoroverlay/add_legend_entry/
Description: Add a Legend Entry to a specified Overlay. The Overlay must have a custom legend before entries can be added to it.
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlay ID
1 REQUIRED (Boolean or multiple boolean values in array [true, false, true]) Add to custom difference legend (false adds the entry to the normal custom legend)
2 OPTIONAL (String or multiple values in array ["a", "b", "c"]) Name (optional)
3 OPTIONAL (TColor or multiple values in array [a, b, c]) Color (optional)
4 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_legend_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_legend_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_legend_entry/", options)
