Api session event editor overlay set entry name
Revision as of 13:19, 3 November 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editoroverlay/set_entry_name/ Description: Change the name of a specified legend entry of a custom legend of a specified Overlay. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID | |- | 1 | REQUIRED | (Integer number) | ID of entry which should be changed | |- | 2 | REQUIRED | (String) | New name for the entry | |} ===Response Codes=== {|class=wikitable !Resp...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (Integer number) ID of entry which should be changed
2 REQUIRED (String) New name for the entry
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_entry_name/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "New name for the entry" ]'
JavaScript example POST
 body: '[ 1, 1, "New name for the entry" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_entry_name/", options)
