Api session event editor overlay set difference entry value
Revision as of 13:19, 3 November 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editoroverlay/set_difference_entry_value/ Description: Change the value of a specified legend entry of a custom legend of a specified Overlay. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID | |- | 1 | REQUIRED | (Integer number) | ID of entry which should be changed | |- | 2 | REQUIRED | (Floating point number) | New value for the entry | |} ===Response Cod...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (Integer number) ID of entry which should be changed
2 REQUIRED (Floating point number) New value for the entry
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_difference_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 53 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_difference_entry_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 42 ]'
JavaScript example POST
 body: '[ 1, 1, 53 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_difference_entry_value/", options)
