Api session event editor overlay remove entry
Revision as of 13:19, 3 November 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editoroverlay/remove_entry/ Description: Remove the specified legend entries from the legend of a specified Overlay. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID | |- | 1 | REQUIRED | (Integer number or multiple integer values in array [1, 2, 3]) | Ids of entries which should be removed | |} ===Response Codes=== {|class=wikitable !Response Code: !Descripti...")
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Ids of entries which should be removed
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_entry/", options)
