Api session event editor overlay add entry
Revision as of 13:19, 3 November 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editoroverlay/add_entry/ Description: Add an entry to the legend of to a specified Overlay. {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) | Overlay ID | |- | 1 | OPTIONAL | (String or multiple values in array ["a", "b", "c"]) | Name (optional) | |- | 2 | OPTIONAL | (TColor or multiple values in array [a, b, c]) | Color (opti...")
0 REQUIRED (OVERLAY Integer ID or multiple integer values in array [1, 2, 3]) Overlay ID
1 OPTIONAL (String or multiple values in array ["a", "b", "c"]) Name (optional)
2 OPTIONAL (TColor or multiple values in array [a, b, c]) Color (optional)
3 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/add_entry/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/add_entry/", options)
