Api session items stakeholders
API Endpoint: /api/session/items/stakeholders/
Edit items with events described at Api session event editor stakeholder.
Default Query:
https://engine.tygron.com/api/session/items/stakeholders/?token=API_TOKENExample Response:
"active" : true,
"client" : null,
"color" : {
"argb" : -3355444
"id" : 0,
"imageName" : "municipality.png",
"imageVersion" : 0,
"lastSelected" : 1791727391751,
"name" : "Municipality Arnhem",
"shortName" : "Arnhem",
"startBudget" : 0.0,
"startBudgets" : {
"0" : 1000000.0
"startCinematics" : {
"0" : 0
"startPoint" : null,
"type" : "MUNICIPALITY",
"version" : 175,
"webToken" : "RHVXnEVpNcbfEBNQKWmwxAXQ"
"active" : true,
"client" : null,
"color" : {
"argb" : -360334
"id" : 1,
"imageName" : "civilian.png",
"imageVersion" : 0,
"lastSelected" : 1741957674390,
"name" : "Inhabitants",
"shortName" : "Inhabitants",
"startBudgets" : {
"0" : 0.0
"0" : 0
"type" : "CIVILIAN",
"version" : 176,
"webToken" : "jzrpvyUfpmxzGM36HjRkd3cx"
} ]Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/stakeholders/?version=100&token=API_TOKENGet Queries
Attributes:
https://engine.tygron.com/api/session/items/stakeholders/attributes/?token=API_TOKENMax version:
https://engine.tygron.com/api/session/items/stakeholders/version/?token=API_TOKENCount:
https://engine.tygron.com/api/session/items/stakeholders/count/?token=API_TOKENSpecific Item by ID:
https://engine.tygron.com/api/session/items/stakeholders/{id}/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/stakeholders/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/stakeholders/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/stakeholders/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/stakeholders/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/stakeholders/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/stakeholders/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/stakeholders/?f=ZIPSMILE&token=API_TOKENApi Model Point
API Model description of Point
| Name | Type | Description |
| type | String | Point |
| coordinates | double[] | x, y, (optional) z |
Api Model Stakeholder
API Model description of Stakeholder
| active | boolean | |
| client | ClientData | |
| color | TColor | Color |
| id | int | |
| imageName | String | |
| imageVersion | int | |
| lastSelected | long | |
| name | String | |
| shortName | String | |
| startBudget | double | |
| startBudgets | Map<int,double> | |
| startCinematics | Map<int,int> | |
| startPoint | Point | Point |
| type | Type | |
| version | int | |
| webToken | String |
Api Model TColor
API Model description of TColor
Api Model Type (Stakeholder)
API Enumeration description of Type
| Name | Description |
| CIVILIAN | |
| COMPANY | |
| EDUCATION | |
| EXPERT | |
| FARMER | |
| HEALTHCARE | |
| HOUSING_CORPORATION | |
| MUNICIPALITY | |
| MEDIA | |
| PROJECT_DEVELOPER | |
| UTILITY_CORPORATION | |
| WATER_AUTHORITY | |
| OTHER_AUTHORITY | |
| OTHER |
