Api session items eventbundles
Revision as of 12:12, 14 October 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/eventbundles/
Edit items with events described at Api session event editor eventbundle.
Default Query:
https://engine.tygron.com/api/session/items/eventbundles/?token=API_TOKEN
Example Response:
  "clientEvents" : [ ],
  "compoundEventBundleIDs" : [ ],
  "description" : "",
  "id" : 0,
  "imageName" : "empty.png",
  "imageVersion" : 0,
  "name" : "Welcome Cinematic Start",
  "serverEvents" : [ {
    "id" : 0,
    "parameters" : [ [ "LogicEventType", "CINEMATIC_STAKEHOLDER_START" ], {
      "@type" : "ItemID",
      "id" : 0,
      "mapLink" : "STAKEHOLDERS"
      "@type" : "ItemID",
      "id" : 0,
      "mapLink" : "CINEMATIC_DATAS"
    }, true ]
    "id" : 1,
      "@type" : "ItemID",
      "id" : 2,
      "@type" : "ItemID",
      "id" : 0,
    }, true ]
    "id" : 2,
      "@type" : "ItemID",
      "id" : 3,
      "@type" : "ItemID",
      "id" : 0,
    }, true ]
    "id" : 3,
      "@type" : "ItemID",
      "id" : 4,
      "@type" : "ItemID",
      "id" : 0,
    }, true ]
    "id" : 4,
      "@type" : "ItemID",
      "id" : 4,
      "@type" : "ItemID",
      "id" : 0,
    }, true ]
    "id" : 5,
      "@type" : "ItemID",
      "id" : 1,
      "@type" : "ItemID",
      "id" : 0,
    }, true ]
  "version" : 7
  "clientEvents" : [ {
    "id" : 0,
    "parameters" : [ [ "ClientEventType", "SHOW_CUSTOM_PANEL" ], 0, true ]
  "description" : "",
  "id" : 1,
  "imageVersion" : 0,
  "name" : "Open Excel Panel",
  "serverEvents" : [ ],
  "version" : 3
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/eventbundles/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/eventbundles/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/eventbundles/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/eventbundles/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/eventbundles/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/eventbundles/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/eventbundles/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/eventbundles/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/eventbundles/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/eventbundles/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/eventbundles/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/eventbundles/?f=ZIPSMILE&token=API_TOKEN
Api Model CodedEvent
API Model description of CodedEvent
Name Type Description
id int
parameters Object[]
Api Model EventBundle
API Model description of EventBundle
clientEvents CodedEvent[]
compoundEventBundleIDs int[] Event Bundles ID
description String
id int
imageName String
imageVersion int
name String
serverEvents CodedEvent[]
version int
