Api session items terrains
Revision as of 12:12, 14 October 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/terrains/
Default Query:
https://engine.tygron.com/api/session/items/terrains/?token=API_TOKEN
Example Response:
  "current" : {
    "type" : "MultiPolygon",
    "coordinates" : [ [ [ [ 657093.832562376, 6800274.005242179 ], [ 657093.832562376, 6799664.916014099 ], [ 658068.3142186847, 6799664.916014099 ], [ 658068.3142186847, 6800274.005242179 ], [ 657093.832562376, 6800274.005242179 ] ] ] ]
  "heightValuesCurrent" : null,
  "heightValuesMaquette" : null,
  "id" : 0,
  "maquette" : null,
  "name" : "1",
  "showSatellite" : true,
  "sourceIDs" : [ ],
  "typeID" : 9,
  "version" : 4
  "current" : {
    "coordinates" : [ [ [ [ 658068.3142186847, 6800274.005242179 ], [ 658068.3142186847, 6799664.916014099 ], [ 659042.7958749932, 6799664.916014099 ], [ 659042.7958749932, 6800274.005242179 ], [ 658068.3142186847, 6800274.005242179 ] ] ] ]
  "id" : 2,
  "maquette" : null,
  "name" : "3",
  "sourceIDs" : [ ],
  "typeID" : 9,
  "version" : 3
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/terrains/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/terrains/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/terrains/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/terrains/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/terrains/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/terrains/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/terrains-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/terrains/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/terrains/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/terrains/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/terrains/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/terrains/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/terrains/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/terrains/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/terrains/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/terrains/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/terrains/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/terrains/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/terrains/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/terrains/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/terrains/?f=ZIPSMILE&token=API_TOKEN
Api Model GeometryCollection
API Model description of GeometryCollection
Name Type Description
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Terrain
API Model description of Terrain
current MultiPolygon MultiPolygon
heightValuesCurrent double[]
heightValuesMaquette double[]
id int
maquette MultiPolygon MultiPolygon
name String
showSatellite boolean
sourceIDs int[] Sources ID
typeID int Terrain Type ID
version int
