UHI formula (Heat Stress Overlay)
Revision as of 07:15, 12 October 2026 by Frank@tygron.nl (talk | contribs)
The Urban heat island effect is calculated[1] using the following formula:
UHImax=(2−Svf−Fveg)⋅S⋅(Tmax−Tmin)3U4
Formula Decomposition
The formula has two parts, the factor and the temperature effect:
UHImax=factor⋅effecttemperature
Factor
The factor is influenced by the sky view factor and the vegetation fraction, both ranging from 0 to 1. When both are low, i.e. barely any sky and no vegetation, the factor is near 2. When both are high, i.e. no surrounding buildings and a lot of vegetation, the factor is near 0. In that case, the resulting heat island effect will be low as well.
Temperature effect
The Urban heat island temperature effect is calculated as:
Daily average global radiation
The S is calculated as follows:
ρair=pRspecific⋅(Tstation+273.15)
S=Qql−avgCair⋅ρair
where,
  • p is the atmospheric pressure, also known as air pressure, with a value of 101325 Pa.
  • Qql−avg is the daily average global radiation in W/m2/hr.
  • Cair is the air heat capacity in J. We use a value of 1007 J.
  • Tstation is the hourly temperature measured at the station.
  • ρair is the calculated air density in kg/m3.
  • Rspecific is the specific gas constant for dry air. We use a value of 287.058 J/(kg·K).
  • 273.15 converts the used temperature from degrees Celsius (°C) to Kelvin (K).
  1. ↑ A diagnostic equation for the daily maximum urban heat island effect for cities in northwestern Europe ∙ N.E. Theeuwes et al. ∙ Found at: https://gert-jan.steeneveld.wur.nl/Theeuwes_JOC_2016.pdf ∙ (last visited: 2026-02-25)
