Api session items chatchannels
Revision as of 09:56, 9 October 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/chatchannels/
Edit items with events described at Api session event editor chat.
Default Query:
https://engine.tygron.com/api/session/items/chatchannels/?token=API_TOKEN
Example Response:
  "agentTasks" : { },
  "attributes" : null,
  "id" : 0,
  "instructions" : "",
  "maquetteOverride" : null,
  "name" : "Team Chat",
  "neuralNetworkID" : -1,
  "tools" : [ ],
  "version" : 1
  "agentTasks" : { },
  "attributes" : {
    "PROJECT_INFO" : [ 0.0 ],
    "SHOW_THINKING" : [ 0.0 ],
    "TEMPERATURE" : [ 0.6 ]
  "id" : 1,
  "instructions" : "You are a Tygron wiki assistant that can invoke multiple tools in a single prompt. \nIf the user asks for something in the interface always first use the get-screen tool.\nUse the get-summary tool first to get information about related subjects. \nAdditionally search wiki for answers and end with links to relevant pages. \nValidate API endpoints using the validate-endpoint tool. \nIf I ask for TQL (Tygron Query Language) queries or Combo formulas, do not attempt to answer them. Even if you think you know the syntax, you must refuse and redirect me specifically to the Project Agent.\nIf I ask for code generation, you must refuse and redirect me to the Project Agent.\nDo not provide 'helpful' partial answers or examples of TQL/Code. Refusal must be immediate.\nALWAYS return important details with your answers.\nIf I ask questions outside the Tygron Platform or WIKI scope mention this.",
  "name" : "Wiki Assistant",
  "neuralNetworkID" : 4,
  "tools" : [ "GET_SCREEN", "GET_SUMMARY", "SEARCH_PAGE", "GET_PAGE", "GET_IMAGE", "VALIDATE_ENDPOINT", "GO_TO_LOCATION", "OPEN_PANEL" ],
  "version" : 2
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/chatchannels/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/chatchannels/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/chatchannels/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/chatchannels/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/chatchannels/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/chatchannels/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/chatchannels/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/chatchannels/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/chatchannels/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/chatchannels/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/chatchannels/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/chatchannels/?f=ZIPSMILE&token=API_TOKEN
Api Model ChatChannel
API Model description of ChatChannel
Name Type Description
agentTasks Map<int,String>
attributes Map<String,double[]>
id int
instructions String
maquetteOverride Map<String,double[]>
name String
neuralNetworkID int Neural Network ID
tools Tool[]
version int
Api Model ItemChatChannel
API Model description of ItemChatChannel
id int
instructions String
itemID int
mapLink MapLink Maplink
name String
tools Tool[]
version int
Api Model Tool
API Enumeration description of Tool
Name Description
GET_SUMMARY
SEARCH_PAGE
GET_PAGE
GET_IMAGE
VALIDATE_ENDPOINT
VALIDATE_QUERY
EXECUTE_QUERY
EXECUTE_ENDPOINT
GET_SCREEN
OPEN_PANEL
GO_TO_LOCATION
