Traffic noise formula (Traffic Noise Overlay)
Revision as of 14:52, 8 October 2026 by Frank@tygron.nl (talk | contribs)
The calculations for the Traffic Noise Overlay follow the standard Calculation Method 1 (SRM 1)[1].
LAeq=E+Co+Cr−Da−Dl−Db−Dm
Dl=0.01⋅d0.9
Dm=max⁡(0.0,3.5⋅(1.0−e−0.04⋅dhs+0.75+hc+0.75))
LAeq = equivalent noise level (dB(A))
E = calculated emission
Co = acceleration term on intersections (default = 0 dB(A))
Cr = reflection term. This term is not used, and by default 0 dB.
Da = distance reduction
Dl = air reduction
Db = surface reduction. This term is not used, and by default 0 dB.
Dm = calculated meteorological reduction
d = distance from the receiver to the source.
e = Euler's number, approximated as 2.7182.
hs = Building datum height (DTM) of the noise source
hc = Building datum height (DTM) of the noise receiving cell.
Default values are taken from InfoMil [1]
Acceleration term on intersections
Accelerating on intersections can cause more noise. This value is only calculated for roads of category INTERSECTION. It is calculated as follows:
Co=1.4+Qv+Qt+QbQc+Qv+Qt+Qb
Qc = number of cars per hour
Qv = number of vans per hour
Qt = number of trucks per hour
Qb = number of buses per hour
Distance reduction
Distance reduction is computed as:
Da=10⋅log10(r)
r = shortest distance between the source and point of evaluation
Traffic Noise.
Emission
Emission is computed as:
E=10⋅log10(10Ec10+10Ev10+10Et10+10Eb10)
E = the combined noise emission
Ec = the calculated noise emission for cars
Ev = the calculated noise emission for vans
Et = the calculated noise emission for trucks
Eb = the calculated noise emission for buses
The emission per type of traffic is computed similarly, with values specific to the type of traffic. It is calculated as follows for car traffic:
Ec=Ec,start+Ec,mult⋅log10(VcV0c)+10⋅log10(QcVc)+σ+τ⋅log10(VcV0c)
Ec,start Emission start value. Configurable with model attribute Emission start (Traffic Noise Overlay). See also: InfoMil [2]
Ec,mult Emission factor. Configurable with model attribute Emission mult (Traffic Noise Overlay). See also: InfoMil [3]
Vc = The traffic type's speed, configured in roads with attribute TRAFFIC_SPEED.
V0c = The traffic type's reference speed, configured per traffic type using the model attribute V0.
Qc = number of cars per hour, configured with Function Value Cars per hour (Function Value)
σ = road surface correction value at reference traffic speed. Configurable in roads with attribute TRAFFIC_NOISE_SIGMA
τ = road surface correction factor per 10 km/hour deviation from reference traffic speed. Configurable in roads with attribute TRAFFIC_NOISE_TAU
  • If traffic amount is a single value, it applies to all defined hours. If it is an array of values, each index corresponds to its respective hour.
  1. ↑ Standard Calculation Method 1 (SRM1) ∙ Found at: http://wetten.overheid.nl/BWBR0031722/2015-07-01#BijlageIII
