Api session items neuralnetworks
Revision as of 07:25, 5 October 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/neuralnetworks/
Edit items with events described at Api session event editor neuralnetwork.
Default Query:
https://engine.tygron.com/api/session/items/neuralnetworks/?token=API_TOKEN
Example Response:
  "attributes" : {
    "BOX_OVERLAP" : [ 1.0 ],
    "INFERENCE_MODE" : [ 1.0 ],
    "MASK_THRESHOLD" : [ 0.9 ],
    "MAX_CELL_SIZE_M" : [ 0.25 ],
    "MAX_GT_INSTANCES" : [ 250.0 ],
    "MIN_CELL_SIZE_M" : [ 0.1 ],
    "PRIORITIZE_LABELS" : [ 0.0 ],
    "SCORE_THRESHOLD" : [ 0.2 ],
    "STRIDE_FRACTION" : [ 0.5 ],
    "VERSION" : [ 2.0241021E7 ]
  "description" : "Test RCNN to detect to detect blue, gray and dark solar\n\t\t\tpanels panels, trained on data from Dutch Neighborhoods. Model is\n\t\t\tstill under heavy development.",
  "id" : 0,
  "legendEntries" : [ {
    "color" : {
      "argb" : 0
    "entryName" : "Background",
    "id" : 0,
    "value" : 0.0
    "color" : {
      "argb" : -16711681
    "entryName" : "Blue solor panel",
    "id" : 1,
    "value" : 1.0
    "color" : {
      "argb" : -3355444
    "entryName" : "Gray solor panel",
    "id" : 2,
    "value" : 2.0
    "color" : {
      "argb" : -13434829
    "entryName" : "Black solar panel",
    "id" : 3,
    "value" : 3.0
  "name" : "test_solar_panels",
  "override" : false,
  "producer" : "Tygron",
  "tensors" : [ {
    "dimensions" : [ 1, 3, 600, 600 ],
    "input" : true,
    "name" : "input_A:RGB_normalized",
    "normalize" : true,
    "type" : "FLOAT"
    "dimensions" : [ -1, 4 ],
    "input" : false,
    "name" : "boxes",
    "normalize" : true,
    "type" : "FLOAT"
    "dimensions" : [ -1 ],
    "input" : false,
    "name" : "labels",
    "normalize" : true,
    "type" : "INT64"
    "input" : false,
    "name" : "scores",
    "normalize" : true,
    "type" : "FLOAT"
    "dimensions" : [ -1, 1, -1, -1 ],
    "input" : false,
    "name" : "masks",
    "normalize" : true,
    "type" : "FLOAT"
  "type" : "RCNN",
  "uploadDate" : 1734698290534,
  "uploaderName" : "Tygron",
  "version" : 1,
  "warnings" : ""
  "attributes" : {
    "MASK_THRESHOLD" : [ 0.3 ],
    "MAX_CELL_SIZE_M" : [ 0.5 ],
    "VERSION" : [ 2.0241111E7 ]
  "description" : "Test RCNN to detect decideous trees, trained on data from\n\t\t\tDutch Neighborhoods. This model is not suitable for dense woods.",
  "id" : 1,
    "color" : {
      "argb" : 0
    "id" : 0,
    "value" : 0.0
    "color" : {
      "argb" : -16711745
    "entryName" : "Decideous tree",
    "id" : 1,
    "value" : 1.0
  "name" : "test_deciduous_trees",
  "override" : false,
  "tensors" : [ {
    "dimensions" : [ 1, 3, 400, 400 ],
    "input" : true,
    "normalize" : true,
    "type" : "FLOAT"
    "input" : false,
    "name" : "boxes",
    "normalize" : true,
    "type" : "FLOAT"
    "input" : false,
    "name" : "labels",
    "normalize" : true,
    "type" : "INT64"
    "input" : false,
    "name" : "scores",
    "normalize" : true,
    "type" : "FLOAT"
    "input" : false,
    "name" : "masks",
    "normalize" : true,
    "type" : "FLOAT"
  "type" : "RCNN",
  "uploadDate" : 1734697444307,
  "version" : 7,
  "warnings" : ""
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/neuralnetworks/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/neuralnetworks/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/neuralnetworks/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/neuralnetworks/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/neuralnetworks/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=ZIPSMILE&token=API_TOKEN
Api Model DataType
API Enumeration description of DataType
Name Description
FLOAT
DOUBLE
INT8
INT16
INT32
INT64
BOOL
STRING
UINT8
FLOAT16
BFLOAT16
UNKNOWN
Api Model DefaultRCNN
API Model description of DefaultRCNN
Name Type Description
attributes Map<String,double[]>
description String
id int
legendEntries LegendEntry[]
name String
override boolean
producer String
tensors Tensor[]
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model Diffusion
API Model description of Diffusion
description String
id int
name String
producer String
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model Embedding
API Model description of Embedding
description String
id int
name String
producer String
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model GenAI
API Model description of GenAI
description String
id int
name String
producer String
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model LLM
API Model description of LLM
description String
id int
name String
producer String
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model LegendEntry
API Model description of LegendEntry
color TColor Color
entryName String
id int
value float
Api Model NeuralNetwork
API Model description of NeuralNetwork
description String
id int
name String
producer String
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model RCNN
API Model description of RCNN
description String
id int
name String
producer String
tensors Tensor[]
type Type
uploadDate long
uploaderName String
version int
warnings String
Api Model TColor
API Model description of TColor
Api Model Tensor
API Model description of Tensor
dimensions int[]
input boolean
name String
normalize boolean
type DataType
Api Model Type (NeuralNetwork)
API Enumeration description of Type
Name Description
RCNN
LLM
EMBEDDING
DIFFUSION
