Api session event editor chat set attribute
Revision as of 07:23, 5 October 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/editorchat/set_attribute/ Description: Set Chat numeric Attribute value {|class=wikitable !Index !Importance !Type !Description !Values |- | 0 | REQUIRED | (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) | Chat Channels | |- | 1 | REQUIRED | (String) | Attribute Name | |- | 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Numeric Attribute Values | |- | 3 | OP...")
0 REQUIRED (CHAT_CHANNEL Integer ID or multiple integer values in array [1, 2, 3]) Chat Channels
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Numeric Attribute Values
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorchat/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorchat/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST
fetch("https://engine.tygron.com/api/session/event/editorchat/set_attribute/", options)
