Api session items skills
Revision as of 09:53, 23 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/skills/
Edit items with events described at Api session event editor skill.
Default Query:
https://engine.tygron.com/api/session/items/skills/?token=API_TOKEN
Example Response:
  "active" : false,
  "content" : "The secret number is 8591",
  "description" : "What is the secret number?",
  "id" : 0,
  "name" : "secret-number",
  "version" : 4
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/skills/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/skills/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/skills/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/skills/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/skills/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/skills/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/skills/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/skills/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/skills/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/skills/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/skills/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/skills/?f=ZIPSMILE&token=API_TOKEN
Api Model Skill
API Model description of Skill
Name Type Description
active boolean
content String
description String
id int
name String
version int
