Api session items zipcodes
Revision as of 09:53, 23 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/zipcodes/
Default Query:
https://engine.tygron.com/api/session/items/zipcodes/?token=API_TOKEN
Example Response:
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/zipcodes/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/zipcodes/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/zipcodes/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/zipcodes/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/zipcodes/?crs=LOCAL&token=API_TOKEN
Bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/zipcodes/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/zip_codes-foo/?crs=3857&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/zipcodes/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/zipcodes/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/zipcodes/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/zipcodes/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/zipcodes/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/zipcodes/?f=JSON&token=API_TOKEN
GEOJSON:
https://engine.tygron.com/api/session/items/zipcodes/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/zipcodes/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/zipcodes/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/zipcodes/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/zipcodes/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/zipcodes/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/zipcodes/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/zipcodes/?f=ZIPSMILE&token=API_TOKEN
Api Model GeometryCollection
API Model description of GeometryCollection
Name Type Description
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of Polygons; Polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model TColor
API Model description of TColor
Api Model ZipCode
API Model description of ZipCode
color TColor Color
id int
name String
polygons MultiPolygon MultiPolygon
sourceIDs int[] Sources ID
version int
