Api session items netclusters
Revision as of 09:52, 23 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/netclusters/
Edit items with events described at Api session event editor netcluster.
Default Query:
https://engine.tygron.com/api/session/items/netclusters/?token=API_TOKEN
Example Response:
  "firstTimeConnect" : true,
  "fractionConnectedOverride" : null,
  "id" : 0,
  "loadIDs" : [ 1, 146 ],
  "name" : "",
  "ownerID" : 0,
  "scenarioID" : 0,
  "version" : 1
  "id" : 1,
  "loadIDs" : [ 34, 284 ],
  "name" : "",
  "ownerID" : 4,
  "scenarioID" : 0,
  "version" : 2
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/netclusters/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/netclusters/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/netclusters/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/netclusters/count/?token=API_TOKEN
Specific Item by ID:
https://engine.tygron.com/api/session/items/netclusters/{id}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/netclusters/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/netclusters/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/netclusters/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/netclusters/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/netclusters/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/netclusters/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/netclusters/?f=ZIPSMILE&token=API_TOKEN
Api Model NetCluster
API Model description of NetCluster
Name Type Description
firstTimeConnect boolean
fractionConnectedOverride double
id int
loadIDs int[] Net Loads ID
name String
ownerID int Stakeholder ID
scenarioID int Scenario ID
version int
