Api session items particleemitters
Revision as of 08:07, 22 September 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/particleemitters/
Default Query:
https://engine.tygron.com/api/session/items/particleemitters/?token=API_TOKEN
Example Response:
  "fileName" : "mediumChimneySmoke",
  "hidden" : false,
  "id" : 4,
  "name" : "Chimney Smoke (Medium)",
  "version" : 11,
  "wind" : true,
  "zBuffer" : false
  "fileName" : "largeChimneySmoke",
  "hidden" : false,
  "id" : 5,
  "name" : "Chimney Smoke (Large)",
  "version" : 1,
  "wind" : true,
  "zBuffer" : false
Limit Queries
Version=100:
https://engine.tygron.com/api/session/items/particleemitters/?version=100&token=API_TOKEN
Get Queries
Attributes:
https://engine.tygron.com/api/session/items/particleemitters/attributes/?token=API_TOKEN
Max version:
https://engine.tygron.com/api/session/items/particleemitters/version/?token=API_TOKEN
Count:
https://engine.tygron.com/api/session/items/particleemitters/count/?token=API_TOKEN
Specific Item:
https://engine.tygron.com/api/session/items/particleemitters/{itemID}/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/particleemitters/?f=HTML&token=API_TOKEN
JSON:
https://engine.tygron.com/api/session/items/particleemitters/?f=JSON&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/particleemitters/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/particleemitters/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/particleemitters/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/particleemitters/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/particleemitters/?f=ZIPSMILE&token=API_TOKEN
Api Model ParticleEmitterModel
API Model description of ParticleEmitterModel
Name Type Description
fileName String
hidden boolean
id int
name String
version int
wind boolean
zBuffer boolean
